1 - 11 of 11 Posts
2018 Lifted 6-speed Crosstrek
So ive been wanting hood struts on the car since I bought it. The Redline kit looks nice, but for $100-140 I did not want to drill into my hood and rivet the mounts in (Plus I would have to spend more to buy a rivet tool haha).
I bought a kit off ebay last year that said it would fit on the 2nd gen, and it didnt. I tried to make it work and it just was not happening. Ended up getting my money back and went back to waiting.
A couple months ago another member posted theirs installed and I got excited! I asked where they got them and it was a different ebay listing. So I decided to buy them as well. This is the listing I purchased from: Fit For Subaru Crosstrek XV 2018 2019 Engine cover Hydraulic Brace Struts | eBay
I ordered them January 10 2020 and they arrived yesterday (Feb 12 2020) so it took just over a month to arrive from China. They did not come with any instructions so I figured id snap a few pics along the way and post up to help anyone in the future. It was pretty straight forward though.
This is everything that came in the kit
The white strip of sheet metal has the nuts tapped onto each end. These nuts are for the posts to bolt into.
I removed most of the tape as seen above.
The red circle is where they get installed
I bent the metal strip so the nut would sit under the hole and still be able to pull the strip off the nut once installed.
Remember to put your washer down before installing the post. I got it hand tight then pulled the white metal strip out then used a wrench to tighten it down fully.
I installed the hood brackets on the bottom stud (closest to the engine) on both sides.
Here is the passenger side
And drivers side
Discussion Starter #2
Here are some pics of them installed
Everything clears just fine. The first time closing the lid I went slow and peeked through the opening before fully closing.
The only thing I would say is that they open the hood JUST SLIGHTLY less than the OEM prop stick. Honestly not a huge deal and wouldnt hinder any basic work in the engine bay. It would have been kinda nice to get some extra opening clearance (Like when you use the prop to FULLY open the hood).
So minus a half to one inch difference in fully open hood, and the 4+ week wait time, these are well worth the money.
Excellent writeup! Hood props are my next install, but I'm looking for some that provide more clearance. I like that Subarus have the option to prop close to 90 degrees, so need to find the right prop kit. It might not be physically possible though, and I might just come up with a custom solution. I like that your kit doesn't require any drilling.
Ya the drilling really turned me off to the other kit.
I would assume if I were to just swap out the shocks for slightly longer ones everything should work as is and open the hood more. Might be something to play around with in the future for myself haha.
2018 Crosstrek Limited
That's really cool!! Thanks for taking the time to document it so thoroughly with great pics!
They included wrenches?
I love the tires and wheels on your car! Can you give me the info as to what they are tires and wheels? I would like to bolt those onto my 2019 Crosstrek Plug-in hybrid. I know they are not the recommended low rolling resistance tires recommended for the plug in hybrid but I don't care. I would think they should bolt on and clearance would be the same?
Discussion Starter #9
Just replied in the other thread ;)
lol yup!
I didnt even use them. I used my ratcheting wrenches to make it a bit quicker.
I never bought ratchetting wrenches. Although I have sockets of almost every description. If it'll fit, I just put sockets on the battery powered impact driver for just about everything.
Discussion Starter #11
You could get a deep socket over the post no problem!
1 - 11 of 11 Posts
