High revs on start up
1 reading
2.5K views 30 replies 13 participants last post by  Gjlatz
Hello all, does anyone know if there is a way of stopping the high engine revs on every start up. I’ll be asking the dealer at next service, wondered if anyone has dealt with the excessive revs.
#8 ·
Hi Kjzoe123, thanks for the reply. Over here in in Scotland it could be the ambient temperature is lower, upon start up it takes 3-5 mins for the revs to get down to around 1000rpm. The frustrating thing is that if you select D or R and the rpm is above 1000 the drivetrain slightly lunges (there’s no clunking). We understand the reasons behind the high revs (1800-2000).
#3 ·
I think it is part of the PZEV setup. The car idles high when cold to try and warm the engine and convertor quickly which helps lower emissions. Not much you can do to change things.
For a short time after the engine has started, the engine speed is kept high.
When the warm-up is completed, the
engine speed lowers automatically.
#9 ·
Thanks for the reply subyrubroo. Can be frustrating waiting for the revs to drop from 2000 to 1000. Can be 5 mins before it’s below 1000 rpm especially if you have to reverse as any revs above 1000 can cause a slight lung from the drivetrain. We just wondered if there was a software update that would stop the high revs.
#7 ·
#24 ·
Putting it into neutral speeds up the process for me.
The blue light will stay on for a while longer but the engine revs will drop down to normal a lot quicker.
From memory it doesn't "lunge" at this point.
Just take it easy on the engine until the oil temps get a bit higher.
I believe the longest part of the normal high engine rev process is the heating up of the catalytic converter to working temperatures. Putting it into neutral possibly only warms the engine oil and skips the catalytic converter part.... If you're bored you can plugin an OBD scanner and read the temperatures.
#25 · (Edited)
OK guys, here is how it works:
This table (or similar) is used for the first roughly 60 seconds after engine start.
Then it switches to this table after roughly 60 seconds after starting:
This is why even on a warm start, it idles at 1200rpm and then drops down a bit after.
#29 ·
If the 1800-2000 RPMs bother you that much, start the engine, put the tranny in Reverse, back down your driveway about 8 feet, and put it back in Park. The RPMs will drop to 1500 or less. Don't know why this works, but it does, and it's especially handy to know in cold weather, where the initial high RPM stage can last 5+ minutes.
Now, would I drive off without the engine and fluids being fully warmed? Not in the New England winter I wouldn't, but you'll find that there are several threads here based on "When is my engine sufficiently warmed up to drive off".
