1 - 7 of 7 Posts
2021 premium 6MT
Is anyone running a full header back exhaust and if so has eliminating 1 of the 2 Cats caused any problems with passing emissions, I’m in NY if that helps we have pretty struck emissions rules not California strict but enough to be annoying?
2013 MT Crosstrek
I was running one cat in CT and got a tune to remove the CEL. All the inspector did was look under the car to see one cat and scan the ECU for problems and I was fine since we took the CEL off
2021 premium 6MT
No problem with emissions??
2013 MT Crosstrek
Wow they checked huh
Yeah, I had to change my manifold back to stock but its possible I could of just gone to a strict shop. Im sure you may be able to find a shop that allows you to run catless exhaust. I tried to look for UEL catted manifolds but they set you back quite a bit more compared to my CNT UEL catless I had
So I'm guessing you have no problem with your vehicle emitting unspent hydrocarbons, nitrogen oxides, and carbon monoxide into the atmosphere just so you can get a small bump in power and that cool sound.
1 - 7 of 7 Posts
