1 - 2 of 2 Posts
The fan speed dial on my 2013 Crosstrek is only working on speed 2. I already replaced the resistor, and that didn't fix the problem. Before it started only working on speed 2, it was only working on speeds 2 and 4. Then 4 went out last week when it started getting cold outside. If it's not the resistor, what is the logical next thing to try?
2014 XV/ I have a similar problem, mine only works on 1 & 3, with 2 being intermittent . I replace the resistor and checked all the fuses, the same problem. Doesn't matter if its A/C or heat so I doubt its an Ac problem. Any suggestions? Thanks in advance
1 - 2 of 2 Posts
