Long time Subaru owner (just sold my 18-year old Impreza Outback Sport), 7 other late model Subarus currently in my extended family (don't know how that happened).
Last week, at 327 miles on my new Crosstrek Limited 2022 the check engine light came on (along with RAB off and Eye Sight off, of course). Subaru towed it back to the dealership. Here are my notes from what the dealership said they found:
Then it gets better. They said they re-routed the wiring to the sensor: all fixed for now. They told me it was fine while they waited for the harness. "Even for my upcoming trip to the U.P. of Michigan and on to Northern Minnesota where I'll be far away from Subaru dealerships at times?" "Certainly," they said.
As I drove away from the dealership the Christmas tree lights lit back up. I turned around. I was sent home with a loaner (2021 Crosstrek Premium, nice to have almost the same car).
The next morning they told me the "master tech." did not work on Friday's and so it would wait for him until Monday. They would not even pull the new codes until then. But the assistant service manager was sure that the wire to the sensor must have been more stressed/damaged than they assumed and that they will find the same error code on Monday and that the wiring harness needs to be replaced.
They say it will be a two-day job, taking over 10 hours. What? One of the service representatives said that the wiring to sensors may not be a single wire, but come as a harness leading to various sensors, so lots of work. I asked if the transmission would be dropped for the service. Yes, they said.
And now the icing on the cake, this is all from a dealership in my town recently under new ownership that lied to me repeatedly during the purchase process (I couldn't find the same model elsewhere so I suffered through their four-hour routine, refusing their various "required" extra charges and services). Clearly this has become a dealership to avoid. I had no intention of further interaction with them (not knowing if the values of the new owners would effect the hiring and behavior in service as it had in sales, but assuming it might). But this is the only local dealership so it is where Subaru had the car towed when it failed nearby. I knew the prior service manager and had learned I could trust him. I don't know the new crowd in the service department now (yes, they all seem to have changed, at least out front).
Any thoughts on how concerned I should be about this upcoming operation to "replace the wiring harness" that includes the wiring to the transmission sensor represented to me as a 10 hour plus job?
Of course, this is all happening under warranty.
I will be reaching out to the SOA customer representatives to explain the situation. (As well as submitting to the Web page they have where they solicit feedback on dealerships to describe the dishonesty we encountered during the purchase.) But for now my first concern is about the work that may begin on the car tomorrow and whether I'll be able to trust the car fresh off this repair when we head north later in the week.
Any thoughts?
My questions:The error code was for "transmission fluid pressure." They found that the wiring harness for this sensor had been incorrectly routed when installed at the factory. It was pulled too tight and was causing an intermittent connection. (And that there were no actual mechanical difficulties with the transmission.) The assistant service manager said that "out of an abundance of caution" she had ordered a replacement harness to install.
- Has anyone heard of this mistake occurring before?
- Does this make sense (anyone know how the wiring to the sensor on the transmission runs and how it might be routed incorrectly)?
Any thoughts?
