Any thoughts on engine bay dress up parts? Fender shrouds, radiator shroud, etc. and do any others fit the newer crosstrek that aren’t made for them? Like Impreza or wrx stuff? I’m not a fan of the colors offered by grimmspeed for the trails line.
I personally don't dress up my engines because, "Weight reduction bro!" but, if you just don't like the color why not paint them?Any thoughts on engine bay dress up parts? Fender shrouds, radiator shroud, etc. and do any others fit the newer crosstrek that aren’t made for them? Like Impreza or wrx stuff? I’m not a fan of the colors offered by grimmspeed for the trails line.
I’ve got caps incoming from billetworkz. I might wind up ordering the grimmspeed trails stuff and re powder coating it.2nd gen crosstreks are pretty limited on what can be done with their engine bays. I have a Engine Bay Caps from Precision CNC Performance (but they're no longer around). I'm sure most engine caps for FA/FB engine should fit. I believe Grimspeed, Billetworkz, and Mele Design have engine bay set caps for crosstreks tho View attachment 313891
This would be nice ^. From experience, I can say the Hybrid cover does NOT fit, even with modification.Probably can make one of the engine covers from a different model fit. The manifold has the threaded inserts in it.
This is exactly where I was hoping this thread would go. I also just noticed Perrin makes an oil filter cover for wrx/Sti/brz. Any reason this wouldn’t fit other models? I didn’t check the oil filter sizes.Did anyone try the FB25 cover from the Forester? For the 2.5 it should be a no brainer, and I would hope it'd fit the FB20 too..
2019-2021 Subaru Forester Engine Cover 14025AA560 | Subaru Parts Store
I guess the oil filter cover only fits the black filter that the brz/wrx use. How different is it from the blue Subaru filter?This is exactly where I was hoping this thread would go. I also just noticed Perrin makes an oil filter cover for wrx/Sti/brz. Any reason this wouldn’t fit other models? I didn’t check the oil filter sizes.
Looks good... Question why have the AOS and a catch can?2nd gen crosstreks are pretty limited on what can be done with their engine bays. I have a Engine Bay Caps from Precision CNC Performance (but they're no longer around). I'm sure most engine caps for FA/FB engine should fit. I believe Grimspeed, Billetworkz, and Mele Design have engine bay set caps for crosstreks tho View attachment 313891
I only have an AOS, and I've found it's nice to have as I drive the car a bit harder than normal. And AOS's have been useful to help my other Subarus (though they are older with more mile but helped with oil burning from wear and tear).Looks good... Question why have the AOS and a catch can?
interesting then what is this in your engine bay?I only have an AOS, and I've found it's nice to have as I drive the car a bit harder than normal. And AOS's have been useful to help my other Subarus (though they are older with more mile but helped with oil burning from wear and tear).
The oil filter cover, assuming you mean the fabric-like covers, won't fit. Based on Fram's Measurements of the filters, the brz/wrx filters are 3.080" height and 3.020" diameter, while the crosstrek filters are 3.469" height and 2.688" diameter. I've looked into this too sadly found they don't fit =(I guess the oil filter cover only fits the black filter that the brz/wrx use. How different is it from the blue Subaru filter?
You mean the cap on my radiator?interesting then what is this in your engine bay?
Lol my bad is that one of the aftermarket billetworks caps you were posting about before?You mean the cap on my radiator?
Weight of a catch can?
What is that 4 lbs.?
probably less
Perrin has an aluminum one. But with those measurements I’m pretty sure it won’t fit.The oil filter cover, assuming you mean the fabric-like covers, won't fit. Based on Fram's Measurements of the filters, the brz/wrx filters are 3.080" height and 3.020" diameter, while the crosstrek filters are 3.469" height and 2.688" diameter. I've looked into this too sadly found they don't fit =(
