1 - 20 of 37 Posts
2019 Crosstrek Limited
Any of you with Weathertechs running into them deforming on the passenger side? This is the second set from them doing the same thing as the first set. I just sent a response back to them about it from the last warranty issue (as I said, same problem as before). Never had an issue like this with weathertechs in the past.
298118
2019 Limited - Suba
I've got Husky in the 'Trek, but have had WeatherTech in 3 other vehicles - never had this issue with any of the floor liners.
I got the Subaru All Weather liners when I got my Crosstrek and after a couple months of ownership, the passenger side mat is doing the same thing. Weird.
Not a Trek but my coworker has a set in his RDX and it's doing the exact same thing. The material seems thin and flimsy.
No problems with our OEM floor mats but we don't leave them in the car when it's hot.
You serious ?
Um, yeah. They get put in the car when it's rainy or when we're heading up into the mountains and it's snowy.
maybe the person who sits there is doing something?
I recommend the 3dmaxpiders over all the others. They provide the same protection, look better. And no way they warp like this.
Yes same problem exactly. I called weather tech and they said to heat it and try to reform it. It worked temporarily but now misshapen again.
I had Weathertechs in a Camry and they warped so much that it impacted the accelerator and brake pedal. I switched to Huskys in the Crosstrek and no movement so far (18 months)
I bought TuxMats, pricey but by far the superior floor mat solution.
I’ve had maxpiders in my 16 Trek since new. They look perfect. They are nicer and way cheaper than weather tech.
Yes! My passenger side started doing this after the dealership detailed my car. Now it slides all over the place
Discussion Starter #20
@Cyndy
My wife just had me walk around to her side because it’s doing exactly like yours is on the inside edge too. Their quality seems to have gone downhill. The ones in my Tacoma are still perfect after a decade.
FYI, this is my second set. When I contacted weathertech the first time about it, they shipped me a whole new set (both fronts and rear), so it’s obviously a design flaw. I think I know what they did wrong too. If someone rides in the passenger side, there’s space underneath the mat just before it rises toward the firewall. So when a person’s feet (and purse) are down there all the time, it pushes the floor mat down causing the sides to pull inward.After that much money spent and two sets doing the same thing, I’ll never buy weathertechs again.
1 - 20 of 37 Posts
