Can someone verify for me if the torque values and procedures that are stated in this service manual are current for a 2018 XV?
www.sucross.com
Ah, that horse has been beat to death, too. With some German cars you cant "drain" the oil anymore.. it's pumped out using a tool. Point is, they never have issues with dirt being suspended in the fluid. That's what the filter is there to remove.Seeing the same torque values in my manual though it is for a 2014. Same CVT though.
It's always better to drain the CVT hot as the dirt is suspended in the fluid. Same with the motor oil.
I can't find the link at the moment but I'm fairly sure someone posted repair manual images from a 2018+ recently.So, I take the given torque values above as correct.. only difference is that the filler plug in the manual I posted is pictured to be on the drivers side, where as on the 2018 XV it's on the passenger side.
You could get at the plug on the drivers side, but you would have to, probably, remove the exhaust that runs by it.
the diagram is correct for 2014-2017. That's the view from the driver's side. The FB2.5 engine has switched the fill to the passenger side since the exhaust is routed differently.So, I take the given torque values above as correct.. only difference is that the filler plug in the manual I posted is pictured to be on the drivers side, where as on the 2018 XV it's on the passenger side.
