1 - 2 of 2 Posts
Hi there!
i love my crosstrek hybrid, but the hybrid system has never seemed quite right.
I feel as if it relies far too heavily on the gas engine, and doesn’t give the electric side a chance.
it truly seems almost as if they should have marketed it as an ‘auto-off during long stops’ mode before calling it a hybrid.
does anyone know of an adjustment or mod that might be able to place more driving emphasis on the electric engine?
thanks in advance!
-Jack
Felt like you in the beginning. But dont forget that it is a real soft hybrid with a powerless eletric engine . 16? Hp if i am not mistaking... And 90? Nm of torgue. Was you in the carsettings and changed the eyesight to ecomode? This raise the use of eletric little bit is my meaning. But you are right too that Subaru should give more options. Stronger eletric brake with better recharge and more often use of the electric engine uphill....
1 - 2 of 2 Posts
