I couldn't justify ~$2K for the Methods and BFGs/Generals setup, so I stuck to the stock rim and had these fitted last Tuesday. Going from a 225/55/17 Kumho Solus TA37, I picked up this Continental set at 225/60.17. They're a little bit taller, more aggressive, and ride fantastic. I've done about 50 miles on them so far with no complaints. Cruising on the highway around 70 I have no noise complaints!If you're in the market for Geolandar's or looking for an A/T tire...this is the one to get. I'll be back with updates soon, looking to hit some north Georgia trails soon.
Didn't need to shave the front flaps, no. I've rubbed 3 or 4 times now at full lock, although there's been no issues with clearance. No life for much, just Rokblokz flaps. A little bit more hum in the drum but nothing terrible. Just need to bump up the tunes a little more if you can't stand road noise
With Winter around the corner, I'm sure many owners are thinking about Winter tires and what sizes will fit the car (both standard 17" and the more common 16" or other sizes). In anticipation of the question "what size will fit", this sticky's purpose is to track Winter tire sizes that people...
The compact temporary spare tire (a.k.a. the donut), has anyone been able to make a new one in a different size or obtain one from something else? Looking for compatibility with 215-75-15 tires. The Subaru Tribeca spare is 165-80-17 and only differs by 1.1% in size but unfortunately does not...
I'm considering a set of Enkei Tuning T6S wheels for my 2020 Crosstrek Premium. Either 17" or 18" diameter. These would be a dedicated wheel set for my non-winter tires. The wheels have an offset of 45mm.
If I go with the 17" wheels and the recommended tire size (225/60-17) the inner...
I was wondering if i need to get a set of mudflaps i have the factory splash guards. Will the tires stick out far enough to throw rocks on the doors or paint? Is anyone running them with factory splash guards only?
