Ok I am going to be serious... I promise @Sarang. Putting aside the ceramic hypothesis for a minute (I just don't want to go there...), the detection system will stop operating when some of the following occur: thick snow around the sensor area; the temperature around the sensor becomes too high/low; or when the vehicle battery voltage becomes too high/low. Or if your car is lifted off the ground and the wheels are freely turning. So I have no idea of what the sister-in-law was doing at the time the little amber light was not on (but should have been), or the environment she was driving in, but it is possible the voltage was low or the temp was too high etc (noting is is summer in the northern hemisphere) and the ECU switched it off then she stopped the car and called in a panic. Then the OP gave her the David Copperfield option and she did the Karate Kid Daniel San wax on wax off wipe. Then got back in the car turned it on and went for a drive and it worked. Then she became ecstatic. Why did it work? Because the sensor had cooled down or the sensor is out of a direct line of sight to the hot sun or the voltage is more normalised due to a number of factors (most likely change in load or the battery had charged up above the cut-off threshold).
Also, it is also possible the sister-in-law hit the switch that turns the sensor off. But I have ruled that out because, unlike Start/Stop where it resets to on after the car restarts, the sensor switch remembers the last state. So if she hit the switch to turn it off then she would have had to also hit the switch to turn it back on. So very unlikely to accidentally hit the switch twice to turn it off then on at specific times.
I also have a grassy knoll theory, but that involves a second ceramic sprayer....
