Another simple way to add cargo lights.
Parts: 12 mm LED bolt lights from Superbrightleds Bolt Beam 12mm LED Light - 55 Lumens , shrink tubing, double wire. It was done on a 2022, however it applies to all model years (since I've done something nearly identical on my 2008 impreza hatchback, also mounting them on tailight access panels)
Light bars or LED strips are also an excellent option, however I was looking for something rather "stealth" and with no glare. The two little acces panels are also excellent in case something needs to be changed, reconnected, etc. If all else fails, they're probably cheap AF to get from a junkyard.
As a side-note, I'm amazed that such a solution isn't nearly standard. The OEM cargo light becomes useless when the trunk is full - and OEM cargo-lights upgrades (such as the one in the Outdoor version in Canada, or pillar-mounted lights from the Japanese accessory catalogue are >100$. Meanwhile, this was a 10$ project...
Write-up:
1) Remove 2 tailight access panels. Run the wire from the right access hole towards the left (no need to rip off the entire trunk cover plastic, one can just tuck the wire in). Drill 2 holes in the acces panels, install lights.
2) Remove the left trunk side plillar, run the wire towards the rubber sleeve connecting the trunk to the car's body. The sleeve just pops out from both sides, and there is enough space to shove the wire in.
3) push the wire down along the D pillar. No need to rip the plastic cover out, it can just be partially lifted. The objective is to get the wire down towards the cargo light (which has to be removed). Once you find the wiggling wire tip, connect it in parallel to the cargo light bulb. You can do it the proper way (solder), or the ghetto way (attach and twist the wire strands to each terminal, hoping they'll stay connected)
Really happy with the result. Perfect illumination, slight spillover behind the car (in case something falls off), and no glare whatsoever due to the optics on the LED bolts.
Write-up:
