1 - 11 of 11 Posts
Hey guys! New member here! This is my first Subaru. I picked up a new K&N cabin air filter like I have for all my family's vehicles. I can't find the filter location. I followed the instructions on the page and looked in the owner's manual's maintenance and service section and no luck.
I took off the glove compartment cover and there isn't the filter housing.
Any info?
That's for older models. It does not look like that when I removed the glove compartment cover, also there was no filter cover in there.
This is from the 2018 Crosstrek owner's manual:
(1) Open the glove box.
(2) Remove the damper shaft from the glove box.
(3) Push in the stoppers located on both sides of the glove box and then pull down the glove box as far as it will go.
(4) Pull out the glove box horizontally and remove the hinge portion. When doing this, be careful not to damage the hinge.
2. Remove the cabin air filter according to the following procedure in order to prevent dust on the air cleaner from falling to the inside of its housing.
(1) Pinch both tabs and remove the filter cover.
(2) Gently tilt down the end of the filter and slowly pull it out 0.4 in (1 cm).
(3) Slowly pull out the rest of the filter.
Thanks man! I searched the manual online and it was broken up into sections. I didn't want to go through the whole thing. I thought it was in the maintenance and service section.
Does anyone have the K&N P/N for the 2021 Crosstrek Sport 2.5 Cabin Air Filter? Same as the 2.0? Thanks!!!
There are good videos on YouTube. Pro tip: empty the glove box FIRST! The process literally takes about 3 minutes.
1 - 11 of 11 Posts
