I wondered that, too. Not that I will be changing my own again but out of curiosity as I've changed a lot of spark plugs in my time (my Jags were V12) and never saw anything like that. Could be a faulty spark plug to shear like that. The fact that you were able to get the threaded part out tells me that wasn't the problem...Good job on the extraction!!
Did the plug break on removal or install? What caused the plug to break? What would you do differently to avoid breaking another plug?
...Just trying to gather an much info as I can before I change mine.
my guess is it was overtightenedI wondered that, too. Not that I will be changing my own again but out of curiosity as I've changed a lot of spark plugs in my time (my Jags were V12) and never saw anything like that. Could be a faulty spark plug to shear like that. The fact that you were able to get the threaded part out tells me that wasn't the problem...
ding ding ding! Yeah it was. It was on the install.my guess is it was overtightened
I doubt itj was over tightened. (IMHO) Plugs are difficult to get out of aluminum heads. The aluminum bonds with the steel as anyone who has worked on motorcycles knows. People tell you to make sure the heads are cool when you remove the plugs. I disagree with that as aluminum expands more than stainless steel. So it it is easier to remove them with the heads war, But I have never done that.ding ding ding! Yeah it was. It was on the install.I guess my advice would be to just go hand tight on the plugs.
Place a one foot long, 3/8" inner diameter vacuum hose over the porcelain of the spark plug. Start threading the plug. Lightly tug to make sure the threading started. Finish tightening the plug. Pull the hose off. Use a 9/16" spark plug socket to tighten5/8 turn or 225*.I doubt itj was over tightened. (IMHO) Plugs are difficult to get out of aluminum heads. The aluminum bonds with the steel as anyone who has worked on motorcycles knows. People tell you to make sure the heads are cool when you remove the plugs. I disagree with that as aluminum expands more than stainless steel. So it it is easier to remove them with the heads war, But I have never done that.
DO NOT GO HAND TIGHT. If you can't torque its a bit over 1/2 turn after hand tight.
I agree with Astro. I have never seen this happen. And at the age of j74 I have removed a "Few"
Congrats for getting it out.
HelloI couldn’t sleep this morning and took a crack at it. I was able to remove it.
soaked? i'll gladly pay $450Dealer charges $450 to replace four spark plugs because nobody would take their car to them when they charged $1,000...It's $450 cause they've found that people are willing to be soaked for the amount.![]()
it's part of the 60k service as i recall which i believe cost me under $700 when i did my 2016. i'm sure it costs more now but i'm okay with that. i charge more now tooI'm with @erader on this one. I grew up helping my dad do all his own maintenance on cars and did so my myself for many years. However, I'm done crawling under cars, getting covered in oil and scraping my knuckles. Besides, I wouldn't even know where to begin with my new to me car...![]()
I have changed mine no engine bolt removal. Using various park plug tool and extension.You’re the second person to mention the possibility of loosening the bolts for the engine mounts and jacking it up a little. I’m hoping I don’t have to since it’s the tube near the battery.
Wonder that’s why the dealer charges $450+ for a spark plug change.
Crush washer fell off lol
AWESOME GOOD FOR YOU!!I couldn’t sleep this morning and took a crack at it. I was able to remove it.
I am just seeing this, I apologize as I haven't been very active on here since adding a 2022 4Runner to the fleet. Hopefully, you made some progress with this already.I try a few extractors with limited tools no luck so far, the valve cover was leaking so I removed it to have more space, and replace the seals, still no luck, no space or angle to try to tap any extractor so far, specially hard to know if I'm taping at the broken part, center of it, mechanics that I have found/called have not helped.
View attachment 315386 View attachment 315387
