1 - 20 of 41 Posts
· Registered
Go to a specialty tool store. You'll need a reversing screw, easy-out, that screw into the hole. Good luck.
Reactions: Joe44usa
· Resident topic drifter
Like a “screw extractor”? I believe I have a set of those.
Or bolt extractor - they have a reverse thread and usually you have to drill a hole in the bolt if, say, you round off the head. You won't need to do that, of course but you may need a very large bolt extractor. The stuck "bolt" also needs to be very well lubricated, maybe soaked with a penetrating oil for a day. Can't imagine how difficult this will be with where the plugs are located on the boxer engine.
I'd also be concerned about any debris that ends up in the cylinder. Overall, not a good situation to be in, sorry...
· Registered
Discussion Starter · #9 ·
I have the same concern about debris. I found the tool I’ll need(Irwin/hanson Ex-5 extractor) luckily It’s #2 cylinder (battery tray) hoping the space will be enough.
· Butchin' Moderator
Don't know if this will help. Square extractor is recommended. Certainly wish you luck and hope that things come together in a non too frustrating way as you work this problem.
· Registered
Discussion Starter · #11 ·
I did see some information about the square extractor. Thank you for the link!
· Registered
2021 Ice SIlver Sport
Oh wow, that doesn't look good. It's bad enough being broken off let alone having no room next to the frame to work. You may have to remove the engine mount bolts and raise it up to get clearance for your extractor. The local Subaru guy says they lift them all to change plugs. I never saw the need but you may have to in this case.
Be sure to remove the crush washer also. Didn't see it stuck on the broken part.
· Registered
Discussion Starter · #13 ·
You’re the second person to mention the possibility of loosening the bolts for the engine mounts and jacking it up a little. I’m hoping I don’t have to since it’s the tube near the battery.
Wonder that’s why the dealer charges $450+ for a spark plug change.
Crush washer fell off lol
Dealer charges $450 to replace four spark plugs because nobody would take their car to them when they charged $1,000...It's $450 cause they've found that people are willing to be soaked for the amount.:cautious:
$1000?! 🤦🏻‍♂️
Sorry, I was being sarcastic and making up numbers. My point is that, from what folks say on this forum, Subaru charges far more than it should for the work of replacing the plugs. Honestly this is my first Subaru and I have not changed the plugs so I really don't know how hard it is.
· Registered
Reactions: nbs0524
1 - 20 of 41 Posts
