I've got the 'loss of power around 2500 rpm' issue that I have seen mentioned a good bit.
Please see the attached graph of rpm and MAF reading. My MAF goes nuts between 2450 and 2550 rpm.
My ECU has also learned to pull a ton of timing in this exact range.
Do any of you with this issue have the ability to log your MAF to see if you are experiencing the same thing? I can easily recreate this by going up a moderately steep hill in 4th gear at 45 mph (6MT).
