2014 XV Crosstrek Limited with about 86,000 miles.
I have noticed this spring that when my A/C is on it is only blowing cold air on the passenger side. I get air blowing plenty on the driver side, but it doesn't appear to be chilled at all. I have some noise coming out of my compressor, but not nearly as bad as videos I have seen from failed compressors. Is there some sort of blend door that could be broken?
I have found that if I run the A/C long enough and eventually turn on air circulation the car stays cooler from the cold air from the passenger side being reused. It however has not had to fight that high of temperatures in the area.
Any suggestions would be helpful.
