41 - 60 of 194 Posts
My belief is that manually adjusting may affect the minimum height possibly but the level to me appears to be purely a sensor since it lowers going up short hills when the car is operating.
I think there may a regulation on left to right as on my Infiniti it would disable if stopped so you couldn't sit and flash oncoming traffic by going left to right on your steering wheel. Those were HID lights.
I think there's a maximum and minimum headlight level electronically adjusted, somewhere between 5-15 degrees from level since mechanical movement of the led/lens assembly have physical restrictions. The same for left/right movement, against physical dimensions in the headlight assembly.
It would be interesting if someone disassembled a damaged led headlight assembly for show and tell. Perhaps a current ('24) service manual has some basic drawings.
Well, after more research, I’ve found that about four out of five 2024 Crosstrek owners seem to think the lights suck. And with SRH, they suck more. If you look around this forum, Reddit, YouTube etc. you will see that I am not alone in my opinion.
The high beams are great. The low beams are bright, but do not shine nearly as far as my old car.
And then there are the ”holes” in the beams.
I guess we’re just silly to expect the fancy lights on our brand new $40K 2024 vehicle should be better than the halogens on my 8 year old CRV.
80% of those who post are grumbling. Some even saying they would have not bought the vehicle, had they known.
10% say they’ve gotten used to it. But why should you have to “get used to it”?
5% seem to not be bothered.
And 5% mock the rest of us.
If you watch the video I posted a few replies ago, you will see just how ridiculous the low beams are.
I‘m still wondering if the Canadian ECE lights are different/better than the US DOT lights?
I joined this forum as a new owner thinking I’d get camaraderie and constructive posts.
Found this in NHTSA
Here's some information from a hopefully neutral source. I was mostly interested in looking at the headlights section.
I have no idea who filed this. I did a search on recalls and I found a page that had two recalls on 2024 Crosstrek and seven complaints. So I followed the link and found the complaint that I screenshot and posted
Do you realize how many have been sold?
Back to your point. What you see is pretty typical of most cars I have driven with LED lights. Sharp cutoff, beams seem low, etc.
I can't say that the Crosstrek is the same as my Impreza RS but outside of the Crosstrek being about 3 inches higher I figure the same body, light packages, etc., make it relative.
When lows are on with shutter type leds the beam when level is not much higher than about the height of the headlights when level, this is pretty much consistent across most cars with LEDs. This puts the beam about trunk high on the car in front of you.
How does this compare with my 2015 Impreza without LEDs? As far as I was concern that Impreza was dim on either beam until one light burned out and I replaced with the best halogen that was DOT approved and was about the best lights I have seen for midrange distances. Either my 2014 Audi or my Impreza RS beats it on distance.
The only fix I see is if there is a way of replacing with a non shutter type light but that probably would cause issues when following other vehicles or raising the shutter and dim the beam itself. I doubt a dealer will tinker with a shutter position if that is even possible. That probably would violate regulations
For me I just use the fog lights and the auto highbeams. My Audi has auto level and an additional set of automatic lights that project at an angle for corners but still has the sharp led cutoffs. In fog mode the LEDs dim and the side lights brighten and two very bright LEDs in the back turn on. When high beams turn on the LEDs are back to bright, the side lights to normal and the back lights are turned off.
I was absolutely not happy with the short distance reach of my '24 headlights. My '20 Outback is excellent. On the Crosstrek I took the 4 adjusting nuts and cranked them a quarter turn. Nope. Still not good enough. I then cranked them another quarter turn. Half turn total. Voila! Equal distance reach of my Outback and no one flashing me. High beams are perfect.
I was absolutely not happy with the short distance reach of my '24 headlights. My '20 Outback is excellent. On the Crosstrek I took the 4 adjusting nuts and cranked them a half turn. Nope. Still not good enough. I then cranked them another half turn. Voila! Equal distance reach of my Outback and no one flashing me. High beams are perfect.
View attachment 319788 View attachment 319788
LEDs?
I am wondering if this simply sets the minimum level because I have been told the sensor adjust is located near the pivot point of the back axle assembly.
Even though I have a 2024 Impreza RS, I drove my friends 2024 Crosstrek Limited last night and his lights on low are a couple of inches higher which indicates both his and mine auto level at about the same angle.
The end result may be similar but possible adjusting minimum (if is what occurred) will affect auto level such as cresting a hill.
After another month of headlight use with my '24, I'm happy with the light distribution and the original adjustment on my car. I see the dark spots, but they don't bother me at all, even during SRH movement.
With that said, I can understand how some people would be unhappy with the headlight throw when the road ahead curves significantly upward. There is so little light above the cutoff directly ahead of the car that I can see how people could feel that the road isn't illuminated far enough ahead of the car.
The auto high beams are effective on my car, and I use them pretty liberally on the rural highways I usually drive, so I haven't felt that driving-into-darkness feeling that I might get if I left the low beams on while approaching a dark upward vertical curve.
Newsflash, light travels in a straight line. A low beam cutoff is a low beam cutoff, there isn't any (in Europe) or barely any (in North America) light above it. If people get frustrated by physics on hilly roads... well just too bad 🙃 It's not as if generations of drivers survived and still do in the Alps or Rockies on subpar incandescent halogen headlamps..
The problem I see with adjusting the housing is with auto leveling lights you may be increasing the hazard on a hill for other drivers and on the level drivers beyond the one you are following.
My friends 2024 Crosstrek lights are level as on the ones on my 2024 Impreza RS. His level is higher than my level. The place to adjust probably should be the level sensor either in its firmware or physically.
Now what would occur if used in conjunction with auto dimming? Could that be tied into a method of a variable low beam based on approaching cars? No vehicles ahead and using low beams the low beams could run slightly higher. The main benefit would be when driving in fog using low beams rather than auto high beam.
If led cutoff is not desired then maybe buy a set of conventional light housings.
Now I wonder just how much tire inflation influences level as my rear tires may be slightly over inflated according to the door sticker. The sensor on some Subarus appear to be just in front of the driver side rear wheel (U.S. models).
Do you recall how/where you did the search? I tried and got no where, including searching the NHTSA database for the number shown on the complaint.
Search by year, make and model. Complaints come up too.
