Trailer Hitch update. I ordered everything from etrailer. This is the third vehicle I have purchased a hitch from them for.
I ordered:
Curt Trailer Hitch Receiver - Custom Fit - Class III - 2"
Hopkins Plug-in Simple Wiring Harness With 4-pole Connector
Hopkins Fold-over Mounting Bracket For 4-way Flat Connector
Etrailer.com Rubber Hitch Cover For 2" Hitches
I selected this particular Curt based on the fact that most of it is concealed behind the bumper. Price was also a factor since I didn't want to pay for the totally concealed ones and then have to remove the center receiver part after each use. I also wanted the 2" receiver since everything I have is 2" already. I also didn't want to do any splicing or tapping into wires or running wires to the front of the vehicle for the trailer lights. This setup met all those requirements.
Their installation videos are amazing for both the hitch and wiring kit. Thats a good thing since the printed instructions (for both hitch and wiring) are not worth very much. Contrary to the instructions, I used a uni-bit to simply enlarge the holes for the bolts and reinforcement pieces that went up into the frame. A wasn't going to try to grind the round hole into a slot then beat the hardware in with a hammer. There is more than enough reinforcement from the piece that goes up inside the frame and behind the bolt to it support behind my enlarged holes. Over all the installation was very easy in my garage by myself.
The Hopkins plug-in kit it also great. It plugs right into the factory harness connector that is at the rear of the vehicle. No splicing, tapping or other nonsense on a brand new vehicle, just plug it in and route the flat plug harness out. I also got the mount for the flat plug which I attached to the underside of the bumper
Overall I'm pleased with how it looks and works. Cost $204.42 to get it all to my door.
