1 - 10 of 10 Posts
Hello and welcome!
My first guesses are a torn boot got dirt in a cv joint or a slightly bent control arm. I’d say go under and have a look but that would have been part of the service.
My second guess is a bad bearing but that should be easily replicable.
Third guess is that the lug bolts weren’t tight so when you turned sharp, you’d hear the it shifting.
Fourth, misrouted brake line.
My 18 has done this since new. For me it's slower and sharper than normal turns. I've always been curious as to what it could be, cause it definitely doesn't sound normal, but figured since it did it from the beginning it most likely wasn't a worn part issue. Unless you strap a gopro under there while turning, I don't know how to pinpoint the issue. It sounds like tire rubbing the plastic fender though, so I suppose any signs of rubbing are a good start.
I will record the sound I have later today.
Hello and welcome!
Wow! That’s a lot of information! Thank you for your reply! It’s just weird that it’s a brand new car and from the get go it’s made this noise. My regret is not taking it in as soon as I heard the noise. I bet they would have jumped all over trying to fix it since it was happening pretty much the next day. Hopefully when I take it back, my car makes the grinding noise. Thanks again for the information!
Yeah same here! If I just turn left or right, no noise. But if it’s a sharp left or sharp right like out of a parking lot, you hear grinding. I’m sorry you’re having the same issue but it’s nice to know I’m not just hearing things lol thank you for your reply!
I'd like to do this myself but I'm actually pretty busy at work today.
Take a read through the the 18' XV NHTSA site and look for any communications or complains that match the symptom. That'll get you started, I hope.
I think I've run into the same on my old 2014.
It only happened on a few occasions when I had to fully turn the wheel in one direction or another while pulling out of a lot or stop sign from a full stop and letting up a little would make the noise stop.
I always assumed it was the fully turned wheel rubbing up against something in the wheel well.
2013 XV Crosstrek Limited
On my 2013, I regularly have a grinding noise from the lip of the brake dust shield rubbing against my rotor as the dust shield slowly rusts away (more so in the rear than the front of the car). It slowly becomes more noticeable over time, to the point that I ended up grinding off the lip and repainting the darn things to slow the rust. Next time I replace the wheel bearings, I'll probably elect to replace the shields and paint them with bed liner to stop the rust this time around. If it's your wheel bearings, you'll likely hear a "whirring" noise at certain speeds and possibly also feel a vibration in your steering wheel (I am familiar as I have replaced the rear bearings twice already at ~150k miles). Good luck!
My 2013 was doing this and it ended up being lower ball joints. Took the dealership a few days of driving to replicate the noise and diagnose.
Discussion Starter #10
I updated my post. If you haven’t been able to figure out your issue,y Subaru dealership thinks it’s the cv shafts. They are ordering me new parts. I take it back on Thursday for them to work on it. I’ll keep my post updated. Hope this helps! 😊
1 - 10 of 10 Posts
