1 - 13 of 13 Posts
2017 Crosstrek
2017 Crosstrek Method MR502 VT-SPEC 2 BFG K02 215/75/15 NO LIFT
Bought my Crosstrek a few months ago and am getting stoked on some upgrades for wheels. I see a lot of threads here but can never find the exact one I'm looking for. Anyway, from what I can tell I think this set up will work. I'm sure I'll get a little rubbing at full lock. Wondering if anyone has done this and any other pros/cons besides some added noise, worse gas mileage, etc. Do 95% of driving on roads (but NYC potholes may as well be off road) and want to get in more light off road and beach driving. Also do a fair amount of snow/ice winter driving upstate NY/Vermont. Any thoughts, tips and confirmation that this set up works would be greatly appreciated.
I believe there's a sticky post somewhere that puts together all the combinations of tire size vs lift or not. But to answer your question. My car has no lift. I have a set of 215/75/15s on +15 Methods that I put on for off pavement activities. They do not rub. Once in a great while when I am backing out of the driveway, I'll hear the slightest rub, but it really is very minor. Otherwise, I've had it on three wheels, have hit pot holes at speeds I won't admit to on the internet, and no problems.
**For the record. a 2 inch lift will NOT clear tires any better than no lift. Look at where it's rubbing and then measure down 2 inches to see what I mean.
This one under construction?
2017 Crosstrek
**For the record. a 2 inch lift will NOT clear tires any better than no lift. Look at where it's rubbing and then measure down 2 inches to see what I mean. View attachment 302049
Thanks. Are you in a 2018 or 2017? From what I can tell the wheel wells in the 2018 and newer models are brighter than the 2017.
cool thanks for your help. Class act.
Class act? How many questions that don't need to be answered do I need to answer? I feel like I answered one too many questions. Best of luck stumbling through figuring out what to do next.
For common questions like this that have been covered a lot, folks on the forums get annoyed sometimes because you could just google it. This thread has your information:
FWIW I'm very happy with my Falken Wildpeak Trails on stock wheels. They come in stock size if you want, or you could bump it up to 225/60R17 for half an inch of free "lift". I don't see much reason to deal with the downsides of K02s, but to each their own.
2017 Crosstrek
Discussion Starter #10
Thank you for the thoughtful reply, appreciate it.
After scouring the forum, I didn't and still can't find anything about a 2017 specifically. If it's out there, shame on me but haven't found it. Also, if it's annoying don't respond. Pretty simple.
2012 to 2017 have the same suspension and wheel wells, so it should apply. If it were me, I would feel comfortable ordering 215/75R15 for the 2017 based on that thread (and others). The fact that Discount Tire CO weighed in is also telling.
You could search for 2017 in r/xvcrosstrek on Reddit for more confirmation, or ask @Discount Tire directly.
Supporting Vendor
Tire & Wheel Specialists
The wheel and tire combination you are considering, although a bit on the aggressive side should work. 28" tall tire looks to be the maximum for your model year. The 215/75 at 27.8" may be a little tight and as mentioned before, may rub at full lock. If you are willing to do minor fender modifications this would be a great option for your purposed driving needs. PM on the way.
1 - 13 of 13 Posts
